46RE late shift after overhaul
Old Mar 3, 2022 | 04:15 AM
  #21
MrLantz's Avatar
MrLantz
Since it seems hopeless to start replacing solenoids and parts in the transmission when I have a wining converter I have now sourced a used 46RE from a '98 Durango (5.2L) with a converter. This should be a direct match, right? (mine is a '99).
The workshop will tare everything down, we'll inspect the transfer case (especially the overdrive housing and direct cluch that we worked on) to make sure nothing seems to have gone wrong there. If everything checks out we will proceed to swap the transmission and converter. I will then take on the challenge of repairing my original 46RE myself. If nothing else it will be a learning experience.
The numbers on my transmission are P52119821AA. I have asked the seller for the numbers on the durango trans.
Old Mar 3, 2022 | 08:02 AM
  #22
Durango trans should be a direct bolt in.
Old Mar 3, 2022 | 08:27 AM
  #23
MrLantz's Avatar
MrLantz
That's great. I will probably pick it up in the weekend and get started next week. I'll keep you guys updated through the process..
Also, just because I'm curious, what info can I get from my currect trans ID? (P52119821AA) And should I check for something particular when I get the donor trans ID? I really want to make sure this is a direct fit..
Old Mar 3, 2022 | 09:17 AM
  #24
The Durango trans *might* have a different stall speed converter, but, I am not sure on that. Aside from that, I doubt there are any differences at all. The 46RE was used in just about everything......
Old Mar 3, 2022 | 11:08 AM
  #25
Thomas bridges's Avatar
Thomas bridges
Yes it will work...(speaking from experience). I put 99 Durango trans in my 98 ram 1500.
Old Mar 3, 2022 | 02:01 PM
  #26
MrLantz's Avatar
MrLantz
P52119285AA is the ID on the donor trans. Still a green light? =) @HeyYou
Old Mar 3, 2022 | 03:08 PM
  #27
Yup. That should work perfectly.
