Are all 360s the same?
Old Mar 28, 2022 | 08:48 PM
Mattskruff's Avatar
Mattskruff
Default Are all 360s the same?
Are all 360 magnums the same? Can I use any 360 parts? From like any year? Also does anyone know where to get parts? Half the time I'm sent to a junkyard just to find parts for my 98 ram.
Old Mar 28, 2022 | 10:20 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Everything is the same other than the intakes. 98 and up has two coolant temp sensors where 97 down only had one.
Old Mar 29, 2022 | 01:08 AM
AtomicDog's Avatar
AtomicDog
You can read about the 360 magnum engine here - https://en.wikipedia.org/wiki/Chrysl....9_L_Magnum_V8
There is a lot of parts that interchange, as the 5.9 engine was used in several Dodge (and Jeep) vehicles, such as:
5.9 Magnum Vehicle Applications
  • 1998-2003 Dodge Dakota.
  • 1992-2002 Dodge Ram.
  • 1992-2003 Dodge Ram Van & Wagon.
  • 1998-2003 Dodge Durango.
  • 1992-2001 Dodge Ramcharger.
  • 1998 Jeep Grand Cherokee 5.9 Limited.
Old Mar 29, 2022 | 08:52 AM
Backwards. 97 and down had two, 98 and up had one.
There are also some differences over the years. 94-95 had EGR, 96 and up did not, though, some 96 trucks had the provision for EGR, but, there was a block off plate instead. The center divider went away at some point as well.
Old Mar 29, 2022 | 11:04 AM
MoparFanatic21
You are right I'm getting old and got them mixed up
Old Mar 30, 2022 | 01:30 PM
ol' grouch's Avatar
ol' grouch
There was also a change in how the engine was balanced in the 1990's. I'm not sure what year.
Old Mar 30, 2022 | 02:25 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
That was mentioned in the earlier supplied web link discussing the 360 engine at the end of the information noted here:
Although the pre-Magnum ('71-'92) and Magnum versions of the 360 cu in (5.9 L) are both externally balanced, the two are balanced differently (the 360 Magnum uses lighter pistons) and each requires a uniquely balanced damper, flywheel, drive plate, or torque converter. Bore and stroke size was 4 in × 3.58 in (101.6 mm × 90.9 mm); compression ratio was 9.1:1.
Old Mar 30, 2022 | 02:28 PM
Up thru 95, the 5.9 magnum engine had a neutral balance flex-plate, and the balance weights were on the torque converter. (automatic transmissions...) 96 and up 5.9, the balance weights moved to the flex-plate, and the torque converter was neutral balance.
Old Mar 30, 2022 | 02:48 PM
AtomicDog's Avatar
AtomicDog
Thanks for adding that additional clarification.
