1995 1500 will not start
Old Mar 31, 2022 | 01:56 PM
jmag18's Avatar
jmag18
Default 1995 1500 will not start
Trying to get my old girl running its a 95 1500 running that was sitting for the past two years. First problem was not getting fuel I replaced the relay once that didn't work I replaced the fuel pump but still no fuel so I jumped the fuel pump relay and got fuel pressure but it wouldn't turn over. I then checked for spark and nothing so I know its a power issue but not sure where to look from here any help would be greatly appreciated
Old Mar 31, 2022 | 02:11 PM
Doesn't crank? Or doesn't fire?
Are you getting power to the coil? Does the fuel pump prime when the key is first turned on? (with the relay in place....)
Old Mar 31, 2022 | 02:15 PM
jmag18's Avatar
jmag18
Yes the motor cranks and no the fuel pump doesn't prime, I am also not getting power at the coil
Old Mar 31, 2022 | 02:16 PM
Does your check engine lite test when you first turn the key on?
Old Mar 31, 2022 | 03:23 PM
jmag18's Avatar
jmag18
No it does not
Old Mar 31, 2022 | 09:52 PM
95RAM360's Avatar
95RAM360
Can you hear the fuel pump kick on? 2 years? I bet in tank strainer is gunked up
Old Apr 1, 2022 | 06:31 AM
Originally Posted by jmag18
No it does not
Check fuses for the ECM..... Make sure it is getting power.
Old Apr 1, 2022 | 06:44 AM
Moparite's Avatar
Moparite
Turn over and cranks means the same thing.
The check engine light should come on as the key is turned to "on" not crank. Might also want to check that the bulb is good.
If it's been sitting that long you should put some fresh gas in it.
Old Apr 1, 2022 | 08:09 AM
jmag18's Avatar
jmag18
No the pump does not kick on unless I jump out the relay. the tank was drained when I put the new pump on so the fuel is ok. I will check out the check engine light. Thanks!
Old Apr 1, 2022 | 09:35 PM
The PCM isn't getting clued in that it needs to trigger the fuel pump, and ASD relays. You likely have a power problem at the PCM, or the PCM itself has failed.
