Rebuilt Motor Knock
Old Apr 12, 2022 | 09:59 AM
  #31
There has been a lot of debate about re-using the intake bolts...... Supposedly, they are torque-to-yield bolts, thus, cannot be re-used. However, there is NOTHING in the service manual that talks about that.... one would think, there would at least be a note in the manual, mentioning that.....
That said, I replace them anyway. Just in case.
Before tearing anything down though, make sure that there is indeed a leak. Timing cover seals up pretty good, unless you are extremely careless, or the sealing surface on the cover is too eroded. (and I really don't think that is the case here.) Re-using the intake bolts *might* give you a leak there, and that would certainly allow coolant into the oil...... But, verify there is a problem before you try and fix it.
Old Apr 12, 2022 | 10:09 AM
  #32
BClark_35's Avatar
BClark_35
yea for now I'm driving it. I was very careful when installing all gaskets, and i havent noticed a coolant leak as of yet. So maybe it was just condensation or something strange. Gonna keep a close eye on everything. Change the oil here in a few weeks. I just don't see how I could have coolant in the oil. We will see. I do still want to drop the pan in a few weeks. Check all the bearings. So far my brand new motor has been hell on earth.
Old Apr 14, 2022 | 05:48 PM
  #33
BClark_35's Avatar
BClark_35
well I'm back. I really don't think i do have a coolant into water leak. At least not yet. Ive driven probably 100 miles and my coolant level is the same. When I drain the oil here soon I will have to make sure. Anyway, I captured a video of a noise my engine is making. It's a bad video but you can hear the noise. Hard for me to pinpoint by myself but it almost sounds like an exhaust leak. I don't think it is though because it only seems to do it with no load. Or at least that I've noticed. It's not a hard knock. But doesn't sound like a tick. Not sure. Any insight is appreciated. As mentioned before no matter what I'm goijg to be dropping my pan and inspecting all bearings.
Old Apr 14, 2022 | 07:45 PM
  #34
Keith_L's Avatar
Keith_L
Originally Posted by BClark_35
{snip}
They felt a little funny when torturing them down but I just thought it was normal.
Honey, is that you????
Old Apr 14, 2022 | 07:53 PM
  #35
BClark_35's Avatar
BClark_35
Now how the hell am i just now seeing that? 😂 looking at that out of context makes me think I'm on the wrong site
Old Apr 15, 2022 | 09:43 AM
  #36
I don't hear anything..... but, my hearing ain't the best either.
Old Apr 15, 2022 | 09:46 AM
  #37
BClark_35's Avatar
BClark_35
every person ive had listen says the same exact thjng but i know it's there😂 if you listen very closely you can hear it. Almost sounds like an exhaust leak to me but that doesn't make sense as I mainly only hear it with no load. Maybe I will find something when I drop the pan. If I don't I'm probably letting it go as "normal". Unless it gets worse
Old Apr 15, 2022 | 10:01 AM
  #38
AtomicDog's Avatar
AtomicDog
Lightbulb
I had an issue/noise like that not long ago. I thought (and my gut was telling me) it was an exhaust leak. I tightened the header bolts up some more (since the gaskets are thick copper and I used copper RTV to further seal them up) and the leak was still there. I decided to take my truck to a local exhaust shop for someone else to look at it. They put the truck on a lift and used a stethoscope to listen around the exhaust system and found that all of the weld joints that were done along the 3" exhaust pipes were leaking at the top of each pipe weld joint, where it appears that the pipe installer missed fully welding the joints along the top area of the pipes. The mechanic there welded up those gaps and all is now well.
Old Apr 15, 2022 | 03:27 PM
  #39
Keith_L's Avatar
Keith_L
Just stick a piece of fuel line in your ear and put the other end near anywhere that might leak. When you find a leak you'll get a distinct puffing noise in your ear
Old Apr 15, 2022 | 04:43 PM
  #40
95RAM360's Avatar
95RAM360
Did you use new lifters? Sounds like a minor lifter tap
