Np241DHD
Old Apr 30, 2022 | 05:19 PM
Codyengelby's Avatar
Codyengelby
Default Np241DHD
Hi everyone my name is Cody so I have this 1996 dodge ram 2500 V10 I just bought it it has the NP241DHD transfer case, so a part of the transfer case Is missing broke off the half that connects the from drive line, so anyway I'll get to the point umm I can drive it as is but I was trying to fine a transfer case I could use just to get it home just so I can run the rear drive line to get it home so I'm was wondering if like the gm NP271 FROM GM would work or be partially compatible maybe another one just so I can hook up rear drive line ,any info would be great thank you in advance
Old Apr 30, 2022 | 08:14 PM
95RAM360's Avatar
95RAM360
Pretty sure the output shaft size is different and I think they’re either a bit longer or shorter, can’t remember, but no I don’t think that’s a go
Old May 1, 2022 | 09:21 AM
Just find the correct t-case, and replace it. There are so many little differences between manufacturers, that it is pretty much impossible to say for sure if something will 'work' or not.
Old May 1, 2022 | 09:38 AM
Keith_L's Avatar
Keith_L
If you fire up your search-fu on the interwebs I had found info on casting numbers on this very thing. But nothing about trying from a different make like GM.
If you do find one note even though it looks like a square bolt pattern it's not. It'll only bolt on one way to keep the oiling groove at the bottom.
These entire 'cases are now stupid expensive in either LD or HD trim, so if you find an entire DHD inexpensively buy it, but more likely you'll be forced to just source the slip shaft housing
Have you noted if the snap ring is still in place on the rear output?? You can see it once the slip shaft housing is removed
Old May 1, 2022 | 10:38 AM
Keith_L's Avatar
Keith_L
This is what I was thinking of, but it's actually only applicable to the LD's
https://mopar1973man.com/topic/5520-...n-housing-fun/
Still, some great tech on that site for the HD's, too, if you search
I forgot the HD's have the big snap ring you also have to spread just to remove the extension housing. LD's just unbolt and slide off
