My Google Fu appears to be inadequate on this one.
As subject states, CEL lit with a p0420. With my daughter's 2000 Honda Civic, I was able to pull up the Mode 6 data via BlueDriver, and it pointed to a specific issue with the downstream O2 sensor. However, with my Ram, it doesn't give much enlightening data:
Anybody have any idea what these "manufacturer defined tests" are, in this case?
Any idea regarding the description of the Mode 6 Test IDs that are failing?
I'm curious, too. If you do figure it out please let us know. I've posted here before wanting to see misfire counts and it's nearly impossible. Codes, sure. Counts, not so much. I mention only because it relates to Mode 6
I'm surprised you're getting a 420/430. I used to service a '98 with the post cat O2 hanging in the wind and it didn't trip the money light.
