Sticking brake
Old May 12, 2022 | 11:03 AM
KameronG7's Avatar
KameronG7
Default Sticking brake
I've just replaced the driver side brake caliper because it was sticking, but it's still sticking.. it only happens when I brake hard, I'm not sure if I should try replacing the brake hose or what
Old May 12, 2022 | 11:04 AM
Jack up the front, take off the tire. Spin the rotor. make note of how much effort it takes. Now, step on the brake pedal HARD a couple times, is the brake sticking? If it is, crack open the bleeder. If the brake then releases, that's a bad line. (soft line) If you change one, change 'em both.
Old May 12, 2022 | 11:51 AM
KameronG7's Avatar
KameronG7
Okay will do, but if it works that means the whole brake line needs to be replaced?
Old May 12, 2022 | 01:02 PM
Just the soft line. They tend to break down over time, and begin to act as a one-way valve.
Old May 12, 2022 | 07:12 PM
ol' grouch's Avatar
ol' grouch
Don't forget the one in back going to the rear brakes from the body to the axle.
Old May 13, 2022 | 05:39 AM
Moparite's Avatar
Moparite
The metal support brackets rust and collapses the hose acting like a one way valve. This happen on both of mine, Gota love the rust belt.
