Overdrive problem
Old May 29, 2022 | 08:25 PM
Gmax's Avatar
Gmax
Default Overdrive problem
My 1998 1500 4x4 will drive for a while and the overdrive will kick off then go for a while and come back on. Any ideas
Old May 29, 2022 | 10:34 PM
Trans is getting hot. Probably the check valve in the cooler line is clogging up. If you have a scanner that can read trans temp, you can verify that. Moving this to Second Gen Ram section.
