4th gen axles on my 2nd gen speed sensor problem Help
If the truck is rear wheel ABS there would only be one speed sensor at the rear differential. The 2013 trucks have sensors on each wheel so that won't work. Even if you hook up one of the wheel speed sensors the number of pulses is going to be different which causes the speedo to be way off. There are electronic speedo correction modules which may be able to make this work but no personal experience.
The following users liked this post:
frsava (05-30-2022)
I swapped a later model 2nd gen disc brake Dana 60 rear over to replace my drum brake Dana 60 rear on my '96 Dodge Ram 2500. I found that the speed sensor mounted on the new disc brake rear had a different connector than the sensor for the '96 drum brake rear. Is it possible to swap the speed sensor on your rear to the sensor that was on your old 1998 rear? When I noticed this difference, I just went out and purchased a new sensor that was listed for '96 for the newer rear and it worked just fine.
The new axle does have two sensors, one at each wheel. I did try hooking up the one to harness connector that went to previous sensor and the ABS light turns off but it doesn't read the speed. I even tried hooking that connector to the transmission output sensor and from there it reads but the numbers are way off.
Trending Topics
Problem solved!
A friend of mine recommended I try a "Universal Speedometer and Tachometer Signal Interface" from Dakota Digital. I could get the sensor near the wheels to work, but by using one on the transmission and spending a couple hours trying different configurations I was able to get consistent readings. Then with a helper and a GPS I was able to adjust in on the road to get accurate readings.
Thanks to everyone for their help. Dertruck- you were right, thanks.
