Stall/No Start Issue
Old Jun 11, 2022 | 12:26 PM
96Sport318's Avatar
96Sport318
Originally Posted by DerTruck
Also make sure the fuel pump ground is good. Looking at the wiring diagram the pump and the level sensor use different grounds so the fuel gauge working doesn't mean the pump has a good ground. The ground runs all the way from the pump back to near the PDC, there are a few grounds at the inner fender near it.
Thank you for this info, I was wondering where the pump grounded. They all look good and when I got it running I gave a little tug on each and nothing. Guess it wouldn't hurt to take them off, clean, and re-install but I don't think its a grounding issue. Anything's possible though, appreciate the info.
Old Jun 11, 2022 | 12:53 PM
AtomicDog's Avatar
AtomicDog
You might have something going on with one of the wires in the connector plug. Might want to pull the plug and have a good look before it happens again. Glad you stuck with it and got it going again.
Old Jun 11, 2022 | 12:56 PM
96Sport318's Avatar
96Sport318
Yea, there has to be something going on there...Unfortunately not much room under there to look around but when I get back I'll give it a look.
Definitely not out of the woods yet, but at least it runs for now. Not looking forward to taking it out again to see if its fixed, nearly positive it will leave me stranded.
Old Jun 11, 2022 | 01:17 PM
Stick with mopar sensors wherever possible. The aftermarket fellers don't always play nice.... and you end up introducing new problems, while troubleshooting others.....
Old Jun 11, 2022 | 01:25 PM
96Sport318's Avatar
96Sport318
Agreed 100%. I didn't see either of those sensors listed as being available from Mopar parts sites online, but I'll check the dealer. Thanks gain.
Old Jun 11, 2022 | 01:54 PM
Use one of the online sites to find the correct part number. (I think rock auto will give ya that too.) Then search by the part number for a source. You can generally find them cheaper online, than from the dealer.
