Tailgate hinge spacing
Old Jun 14, 2022 | 11:13 AM
Keith_L's Avatar
Keith_L
Default Tailgate hinge spacing
I service a '99 where it appears the bed has spread somehow and the tailgate can now move enough side to side to fall off one hinge.
Granted, the plastic bushings are long gone but they alone won't solve the problem -- even if centered each pivot point is barely engaged
I looked at a '98 I also have here which is also missing the bushings and the spacing is MUCH tighter.
RUST ISN'T A THING HERE so this '99 has spread by some other means.....fatigue....built on a Friday afternoon....something
Has anyone else seen this??
I see little choice but to space the hinges away from the tailgate itself where they bolt on, which is entirely possible. I do also have bushings on order (Dorman --- f'n KILL ME NOW, ugh) but that alone ain't gonna solve this problem
Old Jun 14, 2022 | 12:11 PM
Looks like the sheetmetal is bent there where the body-side hinge mounts.....
Old Jun 14, 2022 | 01:08 PM
Keith_L's Avatar
Keith_L
Yeah could be, although in person not so much. Angles and shadows in photos do weird things.
I WILL SAY it's lame Dodge built the body pivots into the bed. GM does them as a separate bolt-on piece and I could have sworn Ford does, too.
Old Jun 14, 2022 | 04:38 PM
If you have some fab skills, probably wouldn't be too bad to come up with some bolt-on mount hinges... Of course, that would require access to the inside of the bed there as well. Don't know if that is even possible without cutting.
Old Jun 14, 2022 | 04:59 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
That sheeting is bent. The two bolts in the van of the picture someone added to try and draw it in.
Old Jun 15, 2022 | 12:50 PM
true blue's Avatar
true blue
Try removing your left tail light ***'y. I'll bet you can get enough access to the inside portion of the hinge mount to '**** 'er a good one' with a 5lb sledge and block of 2X4. Hope you already have a 2X4, a new one will cost more than the pick up is worth!
Old Jun 21, 2022 | 09:51 AM
Keith_L's Avatar
Keith_L
I'm glad you all turned me onto the seam separation in the sheetmetal. I has ASSumed that was mostly cosmetic but turns out there's disturbingly little structure to the bed itself in this area.
I corrected the separation as best I could but even that meant the tailgate was hanging on by 1/32" or less so I spaced one hinge over. I suppose the uniform thing would be to space both but in the interest of time I cut corners, and the gate now functions really well!
Separation left
Separation right
Tail light removed left. Access is very good to use a BFH or air hammer to knock things back into place
Paint removed as best as possible with 2" grinder and copious clamping combined with air hammer blows on the back side
Note washers at TOP of photo to space hinge out. Other hole (finger indicates) was slotted and for good measure I added a 1/4-20 nutsert so the bracket couldn't possibly bend and slide with the newly created slot
Fin. Plus a random Dorman bushing that'll probably fail in a week - it's the only bushing in the assortment that would fit
Old Jun 21, 2022 | 10:48 AM
Looks like the other side where the hinge mounts could stand some of that loving attention too.
Old Jun 21, 2022 | 11:58 AM
Keith_L's Avatar
Keith_L
I did the right at the same time, it was absolutely mandatory and only then I realized I still had to space the tailgate-mounted pivot over with washers
Right side completed
