Compressor pressure switch wiring
Old Jun 19, 2022 | 09:41 PM
kyleo13187's Avatar
kyleo13187
Default Compressor pressure switch wiring
Today I pulled a vacuum and charged the A/C system on my 95 Ram. I noticed the pressor switch on the compressor was not plugged in. I can not find the plug or the wiring that the plug wires into anywhere. Anyone know where this wiring should be?
Old Jun 19, 2022 | 10:00 PM
I think it should come out of the same harness that the clutch connector does. Peel it back, and see if someone cut the wires.
Old Jun 19, 2022 | 10:11 PM
AtomicDog's Avatar
AtomicDog
I have a '96 Ram 2500 with a 5.9. As you can see in the photo, the wiring for the pressure switch should be running along the top of the valve cover in a loom.
Old Nov 12, 2022 | 06:01 PM
Josh1500's Avatar
Josh1500
Thanks to all for the replies. Both went to the bolt on the power steering bracket, was able to match up with the rings they broke off of. Everything is back together and the water pump is leak free .
