Oil passing through pcv
Old Jun 28, 2022 | 12:08 PM
KameronG7's Avatar
KameronG7
Do you mean the seals that are at each end of the intake manifold, the front and back?
Old Jun 28, 2022 | 01:08 PM
AtomicDog's Avatar
AtomicDog
Yes, those are the seals I referred to in the prior post.
Old Jun 28, 2022 | 02:10 PM
I expect some coolant to show up in the lifter valley when you pull the intake. Kinda of a normal thing. If your oil is staying clean on the dipstick, gaskets are probably good. Might wanna test your coolant for combustion byproducts though. Most parts stores will have a kit you can rent for that.
These trucks don't like rare-earth plugs. Leads to mystery random misfires..... Just use good ol' copper plugs.
Old Jun 28, 2022 | 02:53 PM
KameronG7's Avatar
KameronG7
Alright I'll switch over to copper plugs, I removed the throttle body and looked into the intake and the pcv valve was definitely blowing oil in there, but I changed it and cleaned the hose out and it seems to be doing better, my exhaust is still white when I press the gas, but maybe that's from not having a cat, I never payed attention to it before
Old Jun 28, 2022 | 07:37 PM
Test your coolant for combustion stuff. See what it says.
Old Jun 28, 2022 | 08:15 PM
KameronG7's Avatar
KameronG7
How do I do that?
Old Jun 28, 2022 | 08:18 PM
Local parts store will have a kit.
