Cylinder 2 misfire mystery
Old Jul 3, 2022 | 12:18 PM
Potter86's Avatar
Potter86
Default Cylinder 2 misfire mystery
Hey guys I'm at my whits end decoding this issue. I'm hoping some insite from you guys might help.
So cylinder 2 started misfiring about 6 months ago. It would only misfire when wide open throttle(like getting on highway from ramp or stop)
I pulled plug and it's nasty compared to the others. so replaced it. Also put new injectors in. Swapped cables around to see if it was cable(also why I jumped to injectors). There are a lot of things new on it except the engine.
It's a new/used to me. But better shape than my old one. In the end I still have my old engine and heads. I may sent the heads out to get checked and get new everything in them and just swap. But thats a last resort.
Any thoughts ideas appreciated.
Happy 4th all who read!
Old Jul 3, 2022 | 12:35 PM
AtomicDog's Avatar
AtomicDog
What's the compression for cylinder #2 compared to the other cylinders? Sounds like you may have a piston ring or valve problem with the number 2 cylinder, however, more diagnosis needs to be performed to be sure.
Old Jul 3, 2022 | 06:46 PM
Potter86's Avatar
Potter86
I do not yet. I was just sitting here researching again. And when I take it to shop for something else I am lazy to do I will have the give me the numbers. Unless I feel like going to orielly and renting tool.
