2001 Ram 1500 No Bus code, no communication to scan tool
Old Jul 12, 2022 | 01:29 PM
oldsoul13's Avatar
oldsoul13
Default 2001 Ram 1500 No Bus code, no communication to scan tool
I have an 01 Dodge Ram 1500. I was driving it to work one day when it completely shut down all of a sudden while driving. A "no bus" code on the dash popped up, and when I tried to start it again, it would crank but not start and I had to get it towed back to my house. I've been messing with it for a few weeks now and noticed it starts occasionally and if I do get it to start it shuts itself off again and still reads "no bus". I used my OBD2 scanner and get no communication to the ABS everytime whether I get it to start or not. I just replaced my ABS module with a used one I got online and I still have the same outcome as I did before. I replaced my battery as well (not that it would fix it, but it needed a new battery anyway).
I've read that a "no bus" code could be from a bad ABS module, bad PCM, or a bunch of other things lol. Any help would be greatly appreciated on this stressful problem. 👍
P.S. I doubt this has anything to do with it, but I changed my car stereo with a new one a week before my truck started giving me problems. I don't think that would cause anything but maybe you guys know something I don't lol. TIA
Old Jul 12, 2022 | 01:48 PM
Are you getting power to the PCM? Getting spark? Fuel pump prime?
Old Jul 12, 2022 | 08:36 PM
DerTruck's Avatar
DerTruck
Well actually the radio is connected to CCD bus which is what ABS, PCM, instrument panel etc. use. Look for a violet/brown and a white/black wire and make sure they are not shorting or touching ground.
