another 47RE question
Old Jul 28, 2022 | 02:05 PM
moorefield's Avatar
moorefield
Default another 47RE question
I have a 1999 2500 diesel automatic with 215k miles. For years i had shifting issues..but finally took the time to learn how to set the bands. While doing the rear band i changed the filter and solenoids. After this it shifted great....Well, fast forward a year later and for some reason it started shifting badly again.
Problem: it will not shift from 1-2 unless i let off the pedal. When i do this it shifts to 2nd...but when I go back on the gas, the transmission seems confused and revs hard....as if it's in neutral. If i let off the pedal again and slowly accelerate then it shifts smooth all the way to overdrive.
I checked the fluid level and re-set the front band. Also, replaced the speed sensor & replaced the throttle positions sensor (TPS), but no luck. My cruise control & tachometer work great. Before i head to the transmission shop ( money is tight ), I'd like to troubleshoot it further.
Does anyone have a suggestion?
Old Jul 28, 2022 | 02:58 PM
AtomicDog's Avatar
AtomicDog
Have you checked your TV cable to ensure that its adjusted correctly? When you changed the fluid to adjust the bands a while back, how did the fluid look (smell burnt, etc.) and was there much metal in the transmission pan?
Old Jul 28, 2022 | 03:23 PM
moorefield's Avatar
moorefield
have not checked TV cable, but will search the board for 'how to'. Changed fluid looked fine with no burnt smell and no metal on the magnet or pan.
Old Jul 28, 2022 | 09:03 PM
95RAM360's Avatar
95RAM360
Mine did same thing, but it would hang up in 2nd gear let off gas and just touch pedal and it would shift….but yea my tv cable was out of wack but make sure to check return spring….go under truck on drivers side, right about pan level on tranny near bell housing you’ll see the rod the tv cable connects to….make sure spring is there, mine was gone…also have someone hit gas pedal wot (engine off) and watch the rod and make sure it retracts fully when they let off gas
Old Jul 29, 2022 | 01:31 PM
moorefield's Avatar
moorefield
OK, i moved the TV cable in toward the front of the truck to create more slack...now the good news is the 1-2 shifts are about perfect in the 1500-600 rpms range. The bad part is now 2-3 takes too long and i sometimes need to release the pedal to get the shift. Similar to the 1-2 issue just fixed.
I may have moved the TV cable too far so i'm going to remove a little slack and hope that helps. Either way, you guys were right about TV cable needing adjustment. Thanks!!!
Old Jul 29, 2022 | 02:18 PM
AtomicDog's Avatar
AtomicDog
My original TV cable had to be replaced. It had a tendency to bind up and cause shifting issues (even with the return spring at the transmission properly attached), likely due to rust inside the cable housing and age. After I replaced and adjusted the TV cable and now my transmission shifts as it should. It took some time for me to fully realize that the TV cable was not working properly.
Old Jul 29, 2022 | 03:07 PM
moorefield's Avatar
moorefield
This may be my issue...it is a 99 model. I live in the South so it doesn't see snow, but does have some rust here and there. I checked the return spring while doing my front band adjustment so i know that is in order. I'll keep playing with it and respond back so maybe this will help others in the future.
Old Jul 29, 2022 | 04:11 PM
AtomicDog's Avatar
AtomicDog
Same here in central VA, however, since I'm not the prior owner, no telling where this truck has really been in its prior life. My truck did have a snow plow on it at one time in its life (I removed the snow plow frame under the truck after I purchased it), so salt and rust were likely factors in its life at some points.
Old Jul 31, 2022 | 12:00 PM
moorefield's Avatar
moorefield
So, I need to replace the TV cable, but having a hard time verifying for my truck. Does anyone know the proper part #?
Rock auto has two numbers: MOPAR 52107742AC {52107742AB)
When i enter my VIN or truck info, it says the part doesn't fit or cannot be verified.
Old Jul 31, 2022 | 01:20 PM
AtomicDog's Avatar
AtomicDog
Post
You might want to call a Dodge dealer parts department or two in your local area. They can give you the price and part number over the phone, then you can decide to purchase from them or search further for the best deal online you can find (time-permitting, of course)..
