2001 5.2 randomly died won't run
Old Jul 31, 2022 | 11:32 PM
KiloCenturion's Avatar
KiloCenturion
Default 2001 5.2 randomly died won't run
2001 5.2 4x4 NV3500 truck. was driving down the road at about 50 mph and all of the sudden the truck had just died on me. pulled over to side of road and it will crank and crank and crank, it will start but it will only idle at about 400 rpms for a few seconds and then die and if you give it any throttle it will die. any ideas on what this could be?
Old Aug 1, 2022 | 12:34 AM
AtomicDog's Avatar
AtomicDog
Post
Any recent maintenance done on the truck? Have you scanned it for any pending or stored codes? If so, what codes are being displayed? Is the battery in the truck in good shape and fully charged?
Old Aug 1, 2022 | 06:21 AM
95RAM360's Avatar
95RAM360
When you cycle key to on position do you hear the fuel pump start priming?
also could be cam/crank sensor, ignition coil, fist. Cap and rotor…..many things can cause a no start, getting it scanned would be what I’d do if I do hear fuel pump come on
Old Aug 1, 2022 | 07:26 AM
Test fuel pressure.
Old Aug 1, 2022 | 08:16 AM
Moparite's Avatar
Moparite
Test fuel pressure.
X2. Hay moderators, You need to get rid of this...
"The message you have entered is too short. Please lengthen your message to at least 5 characters."
Old Aug 1, 2022 | 11:23 AM
KiloCenturion
the truck has zero fuel pressure, i take it this means my pump has failed?
Old Aug 1, 2022 | 11:26 AM
AtomicDog's Avatar
AtomicDog
Try swapping the fuel pump relay with another relay. If that doesn't get it going, sounds like you have a dead fuel pump.
Old Aug 1, 2022 | 11:48 AM
KiloCenturion
just swapped the horn and fuel pump relay and still nothing, i'm going to replace the fuel pump and hopefully it works
Old Aug 1, 2022 | 05:35 PM
Do you have spark while cranking?
