posi rear
RE: posi rear
Auburn Gear
As far as I know, they're the only aftermarket manufacturer that makes a decent LS/Posi for the 9.25 axle. IIRC, Silver_Dodge has one in his Ram....maybe? [>:]
If you don't do any towing, you could go with a detroit locker. That would be the best option. But then you can't tow with it
You can read more about them at http://www.reiderracing.com/home.htm
RE: posi rear
ARB makes airlockers... they are really fun... PITA if your riding by yourself.. gotta stay on it when going around tight curves.. i think Silver does have an Auburn in his ***... Detriot makes some nasty rears .... things are unbreakable.. depends if your offroading or what you need it for... if its a street only daily driver.. just get the mopar LSD positrac that came option with some packages... me a little cheaper and fit well.. assuming you have an open rearend as it is....
RE: posi rear
ARB doesn't make a differential for the 9.25 rear-end IIRC.
If the TrueTrac is now available for the 9.25, it's def. worth a look as it's an all gear driven differential. Much stronger than a clutch-style differential. I wish it was available for the Dana 70. They have it for the 60 and 80..
