Running rich?
Old Sep 24, 2022 | 07:01 PM
85RAM1995's Avatar
85RAM1995
Ok well it looks like I will be pulling it apart and taking off the Teflon tape and just put it back
Dam I wish I would have thought about that
Old Sep 25, 2022 | 08:49 AM
Moparite's Avatar
Moparite
Don't bother, You can check if it's getting a good ground by using a meter. And the sealant on the factory style ones is a dry sealant that does the same thing as the others. It fits in there tight enough it will make a good ground. I have never had an issue with grounds on pipe threads no matter what sealant i used. Using no sealant will cause it to leak.
