Squeaky front end
Old Oct 12, 2022 | 12:27 PM
HD Kowboi's Avatar
HD Kowboi
Default Squeaky front end
Like the title says, I have a squeaky front end.
I have a 2001 2wd 1500 ram and I've just replaced the upper control arms with ball joints, the lower ball joints, the inner and outer tie rod ends, the pitman arm and idler arm and it's still squeaking like a ford.
I'm about to do the sway bar end links and bushings and possibly the front shocks. Any ideas on why it squeaks so bad? It's driving me crazy.
Old Oct 12, 2022 | 06:09 PM
Will it squeak when it is sitting still? If so, grab another warm body, have them turn the wheels, while you try and locate where the noise is coming from.
Old Oct 13, 2022 | 02:24 PM
HD Kowboi's Avatar
HD Kowboi
Haven't tried that but it does seem to be coming from the right front. I have sway bar end links bushings on the way, think I might order some shocks while I'm at it.
