Fuel filler neck replacement
Old Oct 30, 2022 | 11:11 AM
Keith_L's Avatar
Keith_L
Default Fuel filler neck replacement
I replaced the filler neck on this 2000. After some research I decided on the Spectra Premium FN643 because it would reportedly work with the factory Dodge fuel cap. If you read reviews of some other alternatives they're made to work with older Ford caps -- likely a Chinese manufacturing oversight.
I will say, the Spectra unit felt substantial in the hand, but I was comparing it to the rusted OEM (Chrysler stickers were still present)
https://smile.amazon.com/Spectra-Pre...dp/B005IUKRGY/
Note that Dodge changed the diameter of the steel tube(s) so this won't work for all years of 2nd Gens. I initially tried to use a filler neck from a '96 donor but it was too small to fit the rubber hoses despite otherwise looking nearly identical
Use an impact driver to install the four anchoring screws and they go in nicely
That's not quite a factory bend.
Old Oct 30, 2022 | 11:50 AM
That's something I am going to have to address here in the not too distant future. Mine seems to dribble a bit when filling my tank. As I live in Michigan, rust is most certainly a problem here.
