What determines wot rpm shift points
Old Oct 30, 2022 | 01:23 PM
aerohead's Avatar
aerohead
Default What determines wot rpm shift points
I ask this question because when I recently bought a 1998 SS/T 2 months ago I had wot rpm shifts around 5k. I then did some service on it's trans. I changed oil. filter. adjusted bands,turned up pressure 2 1/2 turns ccw, turned down shift adjuster 1 turn cw, changed out the 2 solenoids in the valve body, changed out new accumulator spring, Installed sonnax manual valve 22771-09, installed sonnax lube regulator 2271A-02k and installed external trans cooler. After all this it shifter like a sports car and I was very happy but my wot rpm shifts went down. My wot rpm from 1st to 2nd is now 45k and the rest upshifts are 42k. I would would like to see them around 5k again. Any idea's.
Thank you in advance
Old Oct 30, 2022 | 01:50 PM
Check adjustment on the TV cable. It has the most influence. For the rest that you did, no idea what the effects of them are.
Old Oct 30, 2022 | 06:38 PM
aerohead's Avatar
aerohead
Thank you for replying. I should have mentioned that the tv cable was checked and was fine. Again, thank you.
I just ordered a Superchip today and when I install it and program 93 octane tune with a tank of 98 I'm thinking it may bring it up.
What do you think?
Old Oct 30, 2022 | 08:33 PM
Quite likely. I think shift points is one of the many thinks the tuners address.
You could try loosening the TV cable one notch, and see if that does anything useful.
