Fuel Gauge Not Working
Old Nov 12, 2022 | 11:20 AM
I don't have the resistance values for the sensor, but, they are likely in the service manual, I would think. Do the math, and see if the voltage reflects anything near how much gas you think it in the tank.....
Old Nov 12, 2022 | 06:40 PM
Raminator7's Avatar
Raminator7
Thank you for all the help thus far….
I remembered yesterday while I was checking the voltage on the blue/white trace wire at the fuel pump connector that I was getting over 10 volts to that wire with it unplugged from the unit. Does that seem high? I remember reading that it should be around 5 volts?
Old Nov 12, 2022 | 08:16 PM
Yeah, the gauge sensor gets its feed from the PCM, which is typically 5 volts.....
Old Nov 12, 2022 | 11:10 PM
Raminator7's Avatar
Raminator7
Here is a trip.
I have noticed that when I get under 10 gallons of gas or less my gauge pins to full and does not move.
I just filled up my 35 gallon tank tonight with 26 gallons of gas and immediately my gauge dropped down to below E.
It will stay on E now until I get low enough on gas again lol.
Gauge is backwards for sure.
Old Nov 25, 2022 | 09:11 PM
Raminator7's Avatar
Raminator7
I ordered a used instrument cluster off of eBay and installed it yesterday. Everything works perfect but the fuel gauge. I back probed the black/blue tracer sensor return wire at the fuel pump and it is reading 50ohms which is accurate with the amount of fuel I have on the tank. Not sure what else to do besides swapping out the PCM.
Old Nov 25, 2022 | 09:12 PM
Plug in with a scanner, and see if you can find what the PCM thinks the gauge state is. Probably need a pretty high zoot scanner to find that little bit of data....
Old Dec 6, 2022 | 11:06 PM
Raminator7's Avatar
Raminator7
So I think I am getting closer to narrowing down the core issue. Tonight I back probed the blue with white tracer wire while it was plugged in to PCM connector 3 and I am only getting .345 volts. I then ran a power wire from the battery and jumped it into that blue/white wire at the PCM connector and the fuel gauge jumped to full.
Old Dec 7, 2022 | 11:01 AM
That should be a 5 volt circuit.... feeding it 12 might cause some issues with other sensors on the same feed.
Old Dec 8, 2022 | 11:38 PM
Raminator7's Avatar
Raminator7
I snipped the black with blue tracer wire (sensor return/PCM 1) as it seemed to have an effect on my low voltage coming from the fuel sensor wire (PCM3). Well, I now have 5 volts coming from the PCM but now the trans temp and od off light came on. Gauge went to 1/8 tank with the fuel light on. I was hoping that sensor return wire to the PCM was only for the fuel gauge but it seems to be running other sensors.
Old Dec 9, 2022 | 09:20 PM
Raminator7's Avatar
Raminator7
The sensor return wire (PCM connector 1 pin 4) for the fuel gauge looks like it splices with multiple sensors. This might explain why my fuel gauge moves to full from dead empty every time I step on the throttle and floor it. There might be a sensor that is grounding out my fuel sensor wire. Any input?
