Could you help me change my fuel filter?
Old Nov 16, 2022 | 05:42 PM
jryhaugan4221's Avatar
jryhaugan4221
Default Could you help me change my fuel filter?
So I am not ashamed to admit than I am a Full Time YouTube engineer, however I cannot find any good videos on how to change the fuel filter for my 1999/318/V8 and I was wondering if anyone could help me with that?
thank you all so much in advance and I hope y’all have a phenomenal day!
Old Nov 16, 2022 | 06:13 PM
Filter is part of the pump module, and isn't generally considered a maintenance item. If you pump fails, then you replace the whole thing, and the filter along with it.
Old Nov 17, 2022 | 07:12 PM
Kentucky Fried Redneck's Avatar
Yeah, on these the filter is integral to the fuel pump. I actually cut an access panel in my bed to make replacing the fuel pump a lot easier after I had one fail under warranty a week after replacing it. I was alone and had no one available to help. If you find yourself in that situation, it's not a bad way to go.
Old Nov 23, 2022 | 11:29 AM
hilliad's Avatar
hilliad
Filter or sock is on the pump in the tank. Not serviceable.
Old Nov 24, 2022 | 09:02 AM
ol' grouch's Avatar
ol' grouch
Well, if you're determined to do it, you either drop the tank or you remove the bed. It's part of the fuel pump assembly. While you're at it, replace the fuel pump too as you've done the hard part of the job already.
Old Nov 25, 2022 | 03:30 PM
What is a full time Facebook engineer? Lol
Old Nov 25, 2022 | 06:16 PM
Sirriggs's Avatar
Sirriggs
Hey is correct. It all one part fuel pump/filter. I can say this. It's not cheap to buy but was a rather easy change for me. My tanks was very close to empty and I found things in the tank that puzzles me. lol. Just don't rush and drop the tank low enough to be able to get to the top of the pump to disconnect. I jacked the right rear up enough to slide it out. Pumped what fuel was in there through a paint filter to keep the gas clean ( Used it for my lawn mower).I pressure washed the tank before removing the pump. I then washed the inside and let it drip dry, then went back and paper toweled it completely dry. Put new pump and it's working great.
