Lost over drive
Old Nov 22, 2022 | 09:21 PM
clarksean918@gmail.com's Avatar
Default Lost over drive
Was driving thru some snow banks lost overdrive. Fuses good switch works.
97 1500 4x4 5.7L no check engine lights
Old Nov 23, 2022 | 12:51 AM
AtomicDog's Avatar
AtomicDog
Year, make, model and engine of your truck? Is the check engine light on? Are you getting any codes that can be read on an OBD2 scanner?
Old Nov 23, 2022 | 01:50 AM
fixed it
Old Nov 23, 2022 | 03:54 PM
5.7?? Or is that a typo? Should be 5.2 or 5.9.
Yeah, need to check for codes.
Old Nov 23, 2022 | 04:45 PM
AtomicDog's Avatar
AtomicDog
Question
Originally Posted by clarksean918@gmail.com
fixed it
Curious - what was the fix?
Old Nov 23, 2022 | 07:51 PM
it seemed to work for a bit but now engine light is on and it is wanting to stall.
Old Nov 23, 2022 | 08:00 PM
Find out what codes it is throwing.
Old Nov 23, 2022 | 08:01 PM
AtomicDog's Avatar
AtomicDog
Sounds like its time to hook up an OBD2 scanner to your truck and find out what codes the PCM is seeing to help diagnosis the issue(s).
Old Nov 23, 2022 | 11:01 PM
misfire on 4 is what it says
Old Nov 24, 2022 | 10:43 AM
Hows the plug on 4 look? Wire? Check under the distributor cap??
