Shaky
Old Dec 18, 2022 | 03:51 AM
JohnsonDodge1994's Avatar
JohnsonDodge1994
Default Shaky
I've had my 94 ran 1500 5.9 for about 8 months now. GREAT truck with only an alternator changed besides a basic tune-up. But I'm having a big prob now. It started with slight missing after it warmed up but nothing major. I thought to change map sensor and while doing that, the check valve & vacuum hose snapped(dry rot) and so I did a quick hose fix until I find a complete fit. But now truck I is shaking badly after it warms up and only while giving gas. Maybe just air leak? Honest-I'm No mechanic. But I've had to drive like that for about a week because it's all I have so I'm asking, will changing check valve/vac hose fix it, or could I have done more damage?
Old Dec 18, 2022 | 07:20 AM
Moparite's Avatar
Moparite
What was the basic tune up? cap rotor plugs and wires? If so what plugs did you put in?
Old Dec 18, 2022 | 10:53 AM
Keith_L's Avatar
Keith_L
I'd suspect TPS or misfire(s). Even if no CEL. Check pending codes. Even if you just replaced plugs or wires, a single bad wire will cause severe bucking under load.
Old Dec 18, 2022 | 12:35 PM
JohnsonDodge1994
I Put in good plus and wires. But I did that about 4 months ago. It really only shakes when it warms up and when I get to around 50-55mph.
Old Dec 18, 2022 | 12:38 PM
That's misfires. Try unplugging the O2 sensor, and see if the problem goes away.
Old Dec 18, 2022 | 12:39 PM
JohnsonDodge1994
I haven't thought about TPS. would that be why it only does it around 50-55mph? Or could it still be only a wire?
Old Dec 18, 2022 | 12:53 PM
Keith_L's Avatar
Keith_L
That's more likely a misfire. You'll need to drive it and keep checking pending codes (if you don't get a hard code). It'll eventually tell you which cylinder is misbehaving
Old Dec 19, 2022 | 06:48 AM
Moparite's Avatar
Moparite
You mean plugs? What brand and type? 8mm wires?
Old Dec 19, 2022 | 09:25 AM
JohnsonDodge1994
I'll try that. Hey thanks everyone who reads these and helps out. Appreciate it. And I might b back on for help
Old Dec 19, 2022 | 10:28 AM
Keith_L's Avatar
Keith_L
You should post your resolution regardless. It may help the next guy like you.
