Shaky
Old Dec 20, 2022 | 12:46 AM
Beartracker981500's Avatar
Beartracker981500
you might also check the vacuum line that goes from the intake manifold to the trans I had the same issue and it ended up being a rotten rubber connector on the transmission
Old Dec 20, 2022 | 12:05 PM
There is no vacuum line going to the trans.
Old Dec 21, 2022 | 06:35 AM
Moparite's Avatar
Moparite
If it's a 4x4 you have a the vac switch on the t case lever.
