HELP with strange Transmission problems
Old Dec 26, 2022 | 05:23 PM
Dataflaw93's Avatar
Dataflaw93
Default HELP with strange Transmission problems
Alright so I have a 96 Ram 1500 with a 5.2 172,000 MI
now the transmission problem is when I shift into 1st on the column the truck jerks and then will not move. But runs fine in drive, reverse or 2nd. I found this problem while replacing the neutral safety switch and transmission speed sensor. The cruise control would not work fixed it and I'm having difficulties getting it to start reliably it makes a gear grinding noise almost and I have to shift it several times back and forth from Park to neutral to get it to crank over
Old Dec 26, 2022 | 05:53 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Sounds like the shift linkage may be slightly out of adjustment. You can download the service manual for your year truck via the link below adjust it according to the service manual. https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old Dec 27, 2022 | 10:27 AM
Dataflaw93's Avatar
Dataflaw93
Much appreciated! I actually have the original service manual, I'll give it a pass over and see what I can find
Old Dec 30, 2022 | 02:40 PM
Dataflaw93's Avatar
Dataflaw93
Default Found the problem!
So after all is said and done. It was the Flexplate causing said issue sadly I'll be dropping the transmission and replacing it as well as the starter
Old Dec 30, 2022 | 03:58 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
I had a 98 GC and a 95 Cherokee that the flexplate cracked on me.
Old Dec 30, 2022 | 09:45 PM
AtomicDog's Avatar
AtomicDog
Exclamation
Hope your truck is 2WD and not 4WD. That would make the job easier, along with doing the job on a lift with a good transmission jack... Glad you found the broken flexplate...
Old Sep 3, 2023 | 12:17 AM
dodgegoburr's Avatar
dodgegoburr
Default Transmission grinds in reverse
I have a 99 dodge 1500 with a 5.9 magnum V8 and 180.000 miles, Now my transmission grinds in reverse if it doesn’t warm up for a half an hour or drive a couple miles, looking for any advice to gets this issue worked out.
Old Sep 3, 2023 | 07:24 AM
Moparite's Avatar
Moparite
Are sure it's grinding or low/starving for fluid? You should have started your own thread.
