Swapping 2000 trans into 99
Old Jan 9, 2023 | 12:55 AM
Mtuck141's Avatar
Mtuck141
Default Swapping 2000 trans into 99
I just swapped a 2000 46re trans into a 99 ram 1500 5.9 magnum, not sure the model of truck the other trans came out of, after starting and driving for approximately 2-5 minutes the trans temp and O/D off lights come on, what could be causing this issue and how to fix it? (Trans will shift into first a second but will not go into 3rd and overdrive)
Old Jan 9, 2023 | 06:31 AM
Moparite's Avatar
Moparite
Some of the sensors changed in 2000,You may have to swap in the ones from the 99.
Old Jan 9, 2023 | 07:19 AM
This.
Governor pressure sensor changed. Also need the mounting bracket from the 99 trans. (that changed as well.)
Old Jan 9, 2023 | 08:57 AM
Mtuck141's Avatar
Mtuck141
Which all sensors changed exactly? All I know of at the moment is the governor pressure solenoid and the transducer
Old Jan 9, 2023 | 05:31 PM
The pressure sensor is what changed, but, so did the connector on it, so you need the whole harness in the trans, along with the correct sensors. I think the TCC and O/D solenoids will be fine though.
Old Jan 9, 2023 | 05:36 PM
Mtuck141's Avatar
Mtuck141
Thank you for the info!
