Flooding out getting spark 🤔
Old Jan 11, 2023 | 06:35 PM
What year is your truck? Is the coolant temp sensor plugged in? (on 97 and older trucks, there are two....)
Old Jan 12, 2023 | 05:39 AM
Rick32's Avatar
Rick32
99 1500 5.9 gas
Old Jan 12, 2023 | 05:41 AM
Rick32's Avatar
Rick32
And no it's faulty atm the two metal prongs are bent and won't accept the plug
Old Jan 12, 2023 | 09:11 AM
There is your problem. Fix that, and it will likely solve the other problems. Right now, the PCM thinks engine temp is something to the tune of -40 degrees.... so it positively DUMPS fuel trying to get a burnable mixture.
Old Jan 16, 2023 | 07:31 AM
Rick32's Avatar
Rick32
Thank you man I will do that thanks for all the help guys
Old Jan 25, 2023 | 07:30 AM
Rick32's Avatar
Rick32
Default Sounds like it's flooding after a warm start
Just recently did a Hughes plenum kit everything went according as far as I'm aware but I'm having the same issue I had in the beginning minus the vacuum leak after a warm start meaning driving the truck for a few minutes s
​​​​​hut it off start it back up it barely starts and gargles through until if idles normalish when and the smell of gas is tremendous during idle so I am aware it is a fuel issue of some sort it has brand new O2 sensors the only thing I am thinking could it be related to PCV valve 🤔👩‍🔧
Old Jan 25, 2023 | 07:32 AM
Rick32's Avatar
Rick32
Starting up but smells like slot of gas dumping runs ruff
Old Jan 25, 2023 | 09:55 AM
Did you fix the temp sensor? Is it reporting something close to what the actual temp is?
Old Jan 25, 2023 | 09:57 AM
Merged your two threads, as they are addressing the same problem.
PCV system has no bearing on fuel mixture.
Old Jan 25, 2023 | 12:04 PM
Rick32's Avatar
Rick32
Spoiler
