ABS light and no speedo
Old Jan 13, 2023 | 12:53 PM
CheeseWheel's Avatar
CheeseWheel
Default ABS light and no speedo
I tried looking it up but no one has the same symptoms I’m having. Occasionally my ABS light comes on and stays on for a full day. It won’t go away during a drive but not come back on later that day. When the light comes on I lose speedometer. The Odometer is still on but I don’t know if it updates. Looking into bad speed sensor the parking brake light tends to be on as well and the speedo works above 30. Neither of those happen for me. I lose it all together and only have the abs light. The truck also won’t shift when this happens. It’ll go 1-2 but no higher.
Old Jan 13, 2023 | 02:50 PM
BrendonM's Avatar
BrendonM
im currently having a similar issue. ABS and BRAKE light on occasionally. My Speedo works 100% of the time though… I’m not sure the problem either. I bought a new ABS speed sensor. Gonna install and see what happens
Old Jan 13, 2023 | 06:16 PM
Bad speed sensor. If your truck is 98 or newer, its on the rear diff.
Old Jan 13, 2023 | 07:00 PM
CheeseWheel
that was my theory. And it’s a 99. Any recommendation for a source of high quality speed sensors?
Old Jan 13, 2023 | 07:44 PM
Mopar if you can find one..... if not, Standard Motor products used to be good.... Not sure if they still are or not.
