Engine rpms slowly climbing in drive
Old Feb 9, 2023 | 01:14 AM
Mtuck141's Avatar
Mtuck141
Default Engine rpms slowly climbing in drive
Just curious if there is something that could be causing this or if it is normal, when flooring it in drive rpms get to 2000 pretty quick but then slowly climb after that, i can hit the gas in park and it easily revs past 2000, could it be spark plugs ir something of that nature? If so, why does it climb slowly in drive but not in park? Could torque converter stall be an issue? I have recently swapped the trans and it is not slipping or anything but torque converter was replaced with a 2300-2600 stall, could that be the issue? Thanks in advance!
Old Feb 9, 2023 | 06:34 AM
Moparite's Avatar
Moparite
Any codes? Might want to check fuel pressure.
Old Feb 9, 2023 | 09:02 AM
Mtuck141's Avatar
Mtuck141
it does have a check engine light, just havent had the time to run a scanner on it
