NV4500 help.
Old Mar 1, 2023 | 02:22 PM
HOSS7769's Avatar
HOSS7769
Default NV4500 help.
I'm building a 98 Ram manual swap. Have a NV4500 and it was just rebuilt. But won't go into first? Any help is appreciated!
Old Mar 1, 2023 | 02:56 PM
AtomicDog's Avatar
AtomicDog
Have you run this question by the person that rebuilt the transmission?
Old Mar 1, 2023 | 02:58 PM
If you shut off the engine, and push in the clutch, will it go into first?
Old Mar 1, 2023 | 03:08 PM
HOSS7769's Avatar
HOSS7769
Sorry, I should have explained it better. It will not go into first off or running but goes into every other gear either way. Only other thing is 3rd is a bit weird. It goes in off only of you pump the clutch 6-7 times.
Old Mar 1, 2023 | 03:09 PM
Talk to the folks that rebuilt the trans. I suspect they screwed something up.
Old Mar 1, 2023 | 03:10 PM
AtomicDog's Avatar
AtomicDog
Is the clutch pedal spongy? If so, need to ensure there are no leaks and re-bleed...
Old Mar 1, 2023 | 03:13 PM
HOSS7769's Avatar
HOSS7769
No leaks. I've checked that multiple times. Pedal not spongy either.
Old Mar 1, 2023 | 05:46 PM
AtomicDog's Avatar
AtomicDog
Sounds like you need to speak with the transmission rebuilder if they're available...
Old Mar 1, 2023 | 07:48 PM
HOSS7769's Avatar
HOSS7769
I called the original guy and the builder has past away. Unfortunately. Thanks though for the help.
Old Mar 1, 2023 | 07:49 PM
Was it done thru a shop, or just 'some guy'?
