Need some advice for next steps
Old Mar 28, 2023 | 08:48 AM
Kgauer21's Avatar
Kgauer21
Default Need some advice for next steps
98 2500 5.9l v8 4x4
im having an interesting idle problem. When the engine is cold, the idle after a few minutes will sound like it’s bogging down and going to die but the RPM’s never change, I can give it some gas and it’ll go back to idling how it’s supposed to.
I’ve changed the IAC valve, and the TPS and cleaned the throttle body.
Old Mar 28, 2023 | 09:41 AM
Did you reset the PCM after changing parts?
Old Mar 28, 2023 | 09:43 AM
Kgauer21's Avatar
Kgauer21
how do I do that?
Old Mar 28, 2023 | 09:44 AM
Disconnect negative terminal at battery. Turn on headlights, turn off headlights, reconnect battery, turn ignition to "On" (don't start it yet.) Count to 10. Don't touch ANYTHING. Start the truck. PCM should figger out idle fairly quickly.
Old Mar 28, 2023 | 10:08 AM
Kgauer21's Avatar
Kgauer21
okay thank you I’ll give that a try after work today
Old Mar 28, 2023 | 10:03 PM
2bit's Avatar
2bit
What brand parts? The parts stores use cheap sensors that don't communicate well with the computer. Use Mopar or Standard Motor Products.. BWD= Broken When Delivered.
Old Mar 29, 2023 | 06:45 AM
Moparite's Avatar
Moparite
If not that soon after you put then in!
