Headlight switch mounts broken
Old Apr 5, 2023 | 10:34 AM
Abel Cortina's Avatar
Abel Cortina
Default Headlight switch mounts broken
I replaced my broken headlight switch because it was loose and seemed to have a short. I noticed the mounts were broken that is why it was loose. I was wondering if anyone has ever repaired them and how did you do it?
Does anyone know what the screw holders' are called for this type of set up?
I was thinking about going to an auto wrecking yard and trying to find a truck (same) that i could cut a piece of the mounts out and have to epoxy them to mine and create a new mount.
Thank you very much.
Abel
Old Apr 5, 2023 | 11:35 AM
Keith_L's Avatar
Keith_L
Funny I just replaced the switch in a 2000 but I don't remember a thing about it. Does it use coarse thread plastiscrews?
Old Apr 5, 2023 | 05:39 PM
Moparite's Avatar
Moparite
Might want to give truck info first!
Old Apr 6, 2023 | 03:13 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Glue gun
Old Apr 27, 2023 | 08:55 PM
J D GA's Avatar
J D GA
Default Yr/Make/Model, etc.
I've always thought
a member's truck info should be a required field in their profile for enrollment here. That's why I put all of mine where it is; might as well, usually need it to get any reasonable responses. No unnecessary posts "what truck?"
Oh no! None of it shows under my pic in a post like it used to. Hmmm.....
Old Apr 27, 2023 | 09:19 PM
Originally Posted by J D GA
I've always thought
I wish folks would put their truck info in their sig. That makes it really easy.
Old Jun 16, 2023 | 09:49 AM
4dptr's Avatar
4dptr
Try to find all the broken plastic pieces, if possible. Or, like you stated a visit to the local boneyard and grab what ya can. Get some quick setting epoxy and have at it...like we all have done. I did my light switch mount last year, right after I replaced my disgusting ugly resemblance of what used to be a dashboard. LMC thank you..
