Injector issues?
Old Apr 15, 2023 | 06:33 PM
Rick32's Avatar
Rick32
Default Injector issues?
Was having issues with engine surging very hard running roughly trying to shut down let it sit over a weekend started it again acted like nothing happened revved it up couple times shut it down when I went to start back up instant misfire ton of white smoke smell like straight gas I've since replaced the PCM with a manufactured correctly matched and the coil pack and the O2 sensor and before all this I have done distributor wires spark plugs distributor button all the way down to a plenum intake kit but the truck ran after all that it just recently started to do this after the initial issue started to misfire could it be a stuck injector fouling out my plug I went and got this new coil after it just started to do this hydrolock issue where it's cranking up half turns a few times then it will grind and stop so I replace the coil and the O2 sensor and it still did the same thing but I did not find what cylinder is possibly flooded or cleaned the plug for being fouled I'm just trying to see if there's any other issues before I go into that
Old Apr 16, 2023 | 06:02 AM
Moparite's Avatar
Moparite
Might try using these.
A period is a small dot-shaped punctuation mark that is used at the end of any sentence that is intended to make a statement.
Old Apr 16, 2023 | 09:20 AM
What are you driving?
