Lifting Engine
Old Apr 29, 2023 | 10:31 AM
Piccalo Pete's Avatar
Piccalo Pete
Default Lifting Engine
Im about to replace my engine mounts on an 01 1500 5.2l 4WD. What are the best points for bolting in a chain to lift the engine.
Old Apr 29, 2023 | 11:26 AM
I think there are a couple bolt holes in the back of the heads, (yeah, fun to get to....) for the front, perhaps some of the bolts for the bracketry? I would use the intake bolts.... unless you put something longer/sturdier in to lift the engine. When I was doing the freeze plugs behind the motor mounts, (they had rusted out) I just put a board between the jack, and the oil pan, to lift the engine. Don't lift too far though, you'll damage the distributor.
Old Apr 29, 2023 | 07:14 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
If you have a reliable bottle or floor jack and a block of wood (to protect the oil pan and spread the load), you can jack up the motor under the oil pan. That should provide enough clearance to change the motor mount.
Old Apr 30, 2023 | 08:58 AM
Moparite's Avatar
Moparite
I had to replace freeze plugs and that's how i did it.
