Oil pump Prime?
With the distributor removed from the engine (assuming you have the new oil pump installed and the oil filter & oil pan back on full of oil), this tool can be inserted and turned with a drill to prime the engine with oil by turning the oil pump - https://www.summitracing.com/parts/sum-901013
This tool works on a variety of Mopar engines (small block magnum & LA, plus big blocks)
The following users liked this post:
dodgetruck2 (05-09-2023)
can it be done without removing the distributor? Like just installing it wet, and turning it over a few times. I think I’ve seen a thread about it somewhere I don’t remember
If it's a fresh rebuilt, you want to prime on the block. However, you are using the same engine with an oil film on the internal surfaces. I trust you are putting a high VOLUME pump and not a high PRESSURE pump. Fill it as best you can then install it. Once its in and the oil pan is filled and you're ready to drive it, disconnect the ignition and crank the engine with the starter until either you have oil pressure on the gauge or the oil light goes out.
I have a melling oil pump. Regular one to just replace oem. Need to do pan gasket and it seems my rear main is leaking. I also have a new Pressure sending unit too. Seems to be super wet around that area behind my manifold. Maybe the rear main is just oil leaking down from the sensor but I’m not sure. Anyway it’s a regular pump for oem. Was going to just replace it while I was up under there. I plan on building the truck so I thought why not.
Trending Topics
Regular pressure is fine. I go with high volume to compensate for worn internal tolerances. The last engine I dropped in as a replacement had 98,000 miles or so. I also slapped a new timing chain set and even replaced the bronze bushing in the block the distributor went through. A friend at a dealer loaned me the installation tool for that. The engine ran another 145,000 miles or so until the frame on the truck failed for the third time and I finally sold it for parts. I sold it to a welder who rebuilt the frame again and as far as I know, "Betty" is still going.
BrendonM (05-12-2023)
alright. Thank you. I’m not 100% sure if I should make a new post about this but randomly today my truck started acting extremely weird. I’m at work and I’m going on my lunch break. When I started it, super loud knock for a good 1-2 maybe 3 seconds. Went away. As I’m driving, I’m pressing the gas down some on and off and I hear a loud click or bang towards the right side of the truck? Maybe directly under my seat I cannot tell. Not only that, when I turn it off. There’s a very loud clicking sound coming from where the starter is, or inside the oil pan. I have video footage of both things occurring. I do not have video of the knocking on start up. I will post to YouTube unlisted and link it, I have no idea what it could be and it just started happening like not even 2 hours ago.
edit: it also is hesitating a bunch. Takes more throttle to get going now. Super random
Alright, the first clip is when driving and the 2nd is after turn off. It’s not the cool down clicking you usually hear.
https://youtube.com/shorts/j64u_P3Kv60?feature=share
I have absolutely NO idea what this is. I pray it’s not super bad.
