2002 Dodge Ram 2500 5.9l magnum drivers side headers glowing HELP!!!
Hello everyone, I’ve been rebuilding my Dodge and doing a restoration, I bought a used motor and had the heads set out, long story short I got the the motor all back together got the distributer set to tdc and then tried to fire it, it ran for 5 minutes and ran awful and both headers started to glow. (I have the shorty headers on my truck). Once I noticed that, I shut the truck down and waited for my scan tool to come in to do the fuel sync. Fast forward to today I did the fuel sync and got it to about 0 but the drivers side headers, cylinders 3 5 7 were glowing still. Should it be more than 0 or less than 0? Is the cam gear off? I’m not really sure what’s going on so I thought I should come here to ask! Thanks!
Zero is the ideal, tolerance is plus or minus 7 degrees. What scan tool did you end up with?
Glowing headers implies you are running lean. So, either a vacuum leak, low fuel pressure, or you have three questionable injectors..
Gonna move this to second gen Ram section for ya. Welcome to DF!
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
Gonna move this to second gen Ram section for ya. Welcome to DF!![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
Hey thanks for the replay and the welcome! I’m happy I found this! Is plus or minus rich/lean? If so which one is which?
I also just got the autel mx808 scan tool and it seemed to do the job! I’ll have to check for a vacuum leak and the fuel pressure to see what I’m actually getting. I did get all new injectors when I got the used replacement motor as I didn’t trust the old ones haha.
It’s very odd to me why the drivers side is the only side that’s still glowing. I did get the eBay special shorty headers haha but hopefully it’s something simple! The idle was up around 1000 too which could be a vacuum leak that’s causing this issue! I’ll check those out and get back with the numbers!
Sorry I gotta harp on this again
. "Fuel sync" is a somewhat misleading name, it does not control any timing, all timing is derived from the crank sensor. It merely tells the PCM which injectors to fire in a rotation :1-8-4-3 or 6-5-7-2. As HeyYou stated the adjustment is actually pretty forgiving with +/- 7 degrees. Also, on 98 up vehicles it is only used to get the engine running, the PCM just goes through the motions afterwards. (Fun fact: modern engine controllers don't even need a cam sensor signal they just change the injector firing until it runs. That's why those 1500+ hp engines in drag&drive events crank a little longer)
I agree something is running really lean there. In addition to fuel trims look at the O2 sensor readings maybe it tells you why the PCM is pulling fuel.
![Smile](https://dodgeforum.com/forum/images/smilies/smile.gif)
