Transmission problem
Old May 22, 2023 | 08:14 AM
hbyler_83's Avatar
hbyler_83
Angry Transmission problem
I have a 1998 Ram1500 5.2 4WD. It’s a 46RE auto trans. Whenever I pull out of the driveway it goes from 1st to 3rd back down to 1st and then to 2nd and then shifts normally. After this going straight is fine but whenever I turn from a stop it does kind of the same thing, goes from 1st to 2nd then back down to 1st and then shifts normally. I thought it was the tranny fluid so I changed it but it did absolutely nothing. Any help would be greatly appreciated
Old May 22, 2023 | 09:20 AM
Any codes? How many miles on it?
Old May 22, 2023 | 10:33 AM
hbyler_83's Avatar
hbyler_83
179908. No codes
Old May 22, 2023 | 11:03 AM
Wouldn't hurt to change the electronics, and do a band adjustment.
Old May 23, 2023 | 12:32 PM
Robt1959's Avatar
Robt1959
You may have to change the Governor Pressure Sensor and the Governor Pressure Sensor Solenoid. I’m in the process of doing that on my 99 Ram 1500 Sport. Not a hard fix.
Old May 23, 2023 | 01:12 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Borg Warner governor pressure sensor solenoid and a Rostra governor pressure sensor. The Rostra's come right off the same line as the OEM but without a P/N. Mines been working for 5 years so far.
