Torque converter not locking up.
Old Jun 3, 2023 | 12:46 PM
Adamg1's Avatar
Adamg1
Default Torque converter not locking up.
Have a 1996 dodge ram 1500 4x4 with a 5.9. Torque converter not locking up. Transmission shifts fine. Have replaced tcc and external transmission plug thinking it mite be bad. Still not working. Any ideas or help would be appreciated....
Old Jun 3, 2023 | 01:03 PM
Any codes? If the PCM doesn't think its working, it should whine about it.
Old Jun 3, 2023 | 01:06 PM
Adamg1's Avatar
Adamg1
There was until I replaced external plug. Drove it yesterday and didn't throw any
Old Jun 3, 2023 | 01:10 PM
Do you get all four gears?
Old Jun 3, 2023 | 01:24 PM
Adamg1's Avatar
Adamg1
Yea. Everything through od. Just not getting rpm drop with lockup. I feel it's electrical. But not for sure.
Old Jun 3, 2023 | 01:39 PM
Is it possible you ARE getting it, just not noticing? TCC engage is pretty subtle, and there just ain't much of an RPM drop either. The PCM just grounds the solenoid circuit for TCC, if it sees the return voltage on the ground wire, and sees the requisite RPM drop, it is perfectly happy. If it doesn't see one or the other, it will set a code.....
Old Jun 3, 2023 | 01:47 PM
Adamg1's Avatar
Adamg1
It is running 3000 rpm at 50 which used to be 1800. I can tell overdrive is working. Cause it has the rpm difference when button is pushed. It has 4 :56 gears in front and rear so it's turning more rpms then stock
Old Jun 3, 2023 | 01:51 PM
TCC isn't going to give you a 1200 RPM drop when it engages..... if it drops 200 or so, that would be normal. How much of a change do you see when you hit the O/D off button?
Old Jun 3, 2023 | 02:06 PM
Adamg1's Avatar
Adamg1
200 to 250
Old Jun 3, 2023 | 02:27 PM
That's TCC, not O/D.
Had any trans or electrical work done recently? How long has this been a problem??
