Transmission look up Help!
Old Jun 19, 2023 | 05:33 PM
skevin's Avatar
skevin
Default Transmission look up Help!
So I have a 1997 dodge Ram 5.9 1500 4x4.
with a 46 re trans
I bought a trans from a guy who said it was a 97 46re 4x4
so I’m ripping apart and if gas different filter 2 screws I’m a plastic case and a square selenoid, compared to mine which had a 3 screw trans filet and round selenoid .
will this work.
I also have serial number off trans if anyone knows a site or how to look it up!
Old Jun 19, 2023 | 06:57 PM
skevin's Avatar
skevin
So i believe after hours of searching it is a 46re form 2000-2002. I think it should bolt in correct?
also my valve body is just re built could I swap my 1997 46 re valve body to this year trans
Old Jun 19, 2023 | 09:37 PM
It may bolt in, but, the electronics will be wrong, and it won't have the provision for mounting the t-case shifter on the trans either.
Old Jun 20, 2023 | 08:41 AM
skevin's Avatar
skevin
So your saying this trans won’t work on my 97?
Old Jun 20, 2023 | 08:53 AM
skevin's Avatar
skevin
Old Jun 20, 2023 | 01:26 PM
Check the case, if it doesn't have the mounting bosses for the t-case shifter.... nope, won't work. The electronics can be changed, if the bosses are there.
Old Jun 20, 2023 | 07:32 PM
skevin's Avatar
skevin
Yes I am a rookie trying to complete this.
sorry I’m a little close fused by the t case shifter statement and I hope you can’t be patient with me and help explain so j get it or I can tkae come pictures. I wound hate to re build it drop mine and it be wrong. Boy would I have mess them
Old Jun 20, 2023 | 07:46 PM
skevin's Avatar
skevin
Hey you! if I post some picture tomorrow of it can you help me out and let me if I should be good thanks
If he had it in a 97 4x4 it should work correct?
Hey no mater what the outcome I appreciate your help and opinion.
Old Jun 20, 2023 | 08:50 PM
If you can post some pics of the trans, we can tell ya if it'll work or not. If he already had it in a 97, then chances are good it will bolt right into yours as well.
Old Jun 21, 2023 | 06:54 PM
skevin's Avatar
skevin
Hey you. Hopefully you get on line to check these out…thanks bud for all the help
