Transmission help
Old Aug 1, 2023 | 12:46 AM
Rug.muncher's Avatar
Rug.muncher
Default Transmission help
Im not a huge truck/car person have two transmissions that came of off two different second gens both are 24 valve 5.9L one transmission is stamped 238-4 and the other is 238-3 which is apparently a built transmission, but they can’t be swapped between the two the 238-3 on the inside where the spline is, is shorter causing about a 1/2 inch gap between where it mounts to the engine. Did I get sold the wrong transmission or do I need to get a different torque converter? literally can’t find anything online
Old Aug 1, 2023 | 07:23 AM
They should be exactly the same..... Where is the gap you are talking about? Engine to trans mount? If so, probably the torque converter isn't completely seated.
