Curious to slipping in 3rd
Old Aug 10, 2023 | 01:18 AM
Sirriggs's Avatar
Sirriggs
Default Curious to slipping in 3rd
I know I drive some of you crazy but I was thinking. I believe this was my problem before doing a rebuild on this 46re transmission. As some of you know that everything has been replaced. I am going to do a fluid check by this weekend to make sure it's not low. I did a sharp turn both left and right and it didn't slip as it normally would if fluid was low. I did a trouble shooting guide and it really doesn't give much information with slipping then fluid level. It's looking like 2 to 3 weeks before a local transmission could take a look at it. 1st and 2nd seem to be shifting but 3rd seems to be the issue. I was waiting for it to hit around 500 miles before I was going to do a fluid drop and strain to remove that debris I believe is from the new friction disk. I haven't driven it for about a week since it was slipping bad enough that I thought I was going to make it home and it didn't even go into limp mode either. I have no codes other then the speed sensor which was replaced before it started to slip like it's doing now. I was experiencing on the work the same day. That was when it threw the code. Until I can get them to check it. It's a guessing game? My thoughts is either the pump or the valve body is causing it? I am wondering if maybe this debris has clogged something up? I couldn't get the lower line to come off. The one with the check ball.
My question is has anybody had these same symptoms and could give an idea of what to maybe try? I dread the transmission shop because I'm sure it wont be a cheap fix. lol
Old Aug 10, 2023 | 06:21 AM
Need to see what pressures are doing in third......
Old Aug 10, 2023 | 06:05 PM
Sirriggs's Avatar
Sirriggs
Yeah, I agree. Just hard sitting here not being able to do anything. lol. Thanks.
Old Aug 11, 2023 | 12:05 PM
69_XS29L's Avatar
69_XS29L
Been looking for a good reason to post this link. Diagnosis of trans troubles, 47RE using home built gauges.
If you have a service manual, you do right? ,this will point you in the correct direction, port locations differ a bit.
https://mopar1973man.com/cummins/art...ng-guide-r622/
Very useful.
This guy also has a write up on the late model T-Style HD steering linkage conversion with part numbers, along with a lot of other GenII Ram tech, mostly oriented towards Cummins stuff.
Old Aug 12, 2023 | 08:49 AM
Moparite's Avatar
Moparite
Or use this...
https://www.trucktransdiag.com/downl...nsmissions.pdf
Old Aug 12, 2023 | 06:40 PM
Sirriggs's Avatar
Sirriggs
Thanks Guys. Everything is on hold at the moment with this heat. It's just been way too hot to even spend anytime outside.
Old Aug 12, 2023 | 07:34 PM
In Florida? Yeah, I can believe that.... I live in Michigan, and Florida was too hot and humid in friggin MARCH the last time I was there.
Old Aug 13, 2023 | 12:58 AM
Sirriggs's Avatar
Sirriggs
Pretty much every day has been in the 90s feeling like 105 all day. High 80s at night. I am doing 2 to 3 shirt changes at working daily. Went out this morning around 6:30 am and with in maybe 15 minutes I was wet and sweaty. Just gave up and went back inside.
