2000 ram 5.9l 1500 truck. Fires and dies 50lbs at fuel rail. Help please
08-19-2023, 03:46 PM
on
Mikeparrott61
Ok , did that . No change. Remember i can pour fuel down throat and it runs till i stop.
08-19-2023, 03:47 PM
on
Mikeparrott61
I have the manual chilton.
08-19-2023, 03:59 PM
on
Mikeparrott61
Also checked asd relay for power while cranking and it stays ingauged. Only off when 3sec no crank happens.
08-19-2023, 04:01 PM
Quote:
Originally Posted by
Mikeparrott61
Exactly so almost surely your fuel pump is not running or not continuing to run. Jump the terminals at power distribution center and see what happens.
Are you truly seeing 50psi at rail
while cranking?????
Mikeparrott61
So, nothing. Chilton is good for kindling. Maybe posterior shine in a bind.
08-19-2023, 04:09 PM
on
Mikeparrott61
Actually the pump guage hooked to the rail fluctuates between 40 to 50 psi when cranking. And 48 psi when I stop.
08-19-2023, 04:19 PM
on
Mikeparrott61
Jump relay pump runs continuously. And 48 psi no cranking. And fluctuates 40 t0 48 during crank.
08-19-2023, 04:22 PM
Dodge Forum Administrator
With the pump relay jumpered, will the engine continue to run?
The following users liked this post:
08-19-2023, 04:26 PM
on
Mikeparrott61
No , no change starts an dies.
08-19-2023, 05:14 PM
If you keep feeding it fuel will it stay running?
08-19-2023, 05:34 PM
on
Mikeparrott61
Yes untill we stop feeding
