46rh temp sensor?
Old Aug 27, 2023 | 03:46 PM
MtnTow's Avatar
MtnTow
Default 46rh temp sensor?
Id like to put a temp sensor on my 47rh. I know the RE series has deeper pans for the mod but would that work for RH?
Could i weld a bung in somewhere safely?
Old Aug 27, 2023 | 05:21 PM
Drop the pan (change fluid and filter, adjust the bands while you are in there....) and see if you have reasonable spot.... Stock, the sensor was in the cooler line at the front of the trans, about four inches from the trans. Don't know if those lines are still available though.
Old Aug 27, 2023 | 06:31 PM
MtnTow's Avatar
MtnTow
I adjusted the bands a couple years ago and was looking but couldnt really tell if any of the open areas could affect flow or anything.
i think i may actually still have have the oem sensor in line but id have to look. Are you saying i could tap it for a dash gauge?
Old Aug 28, 2023 | 07:26 AM
Probably. Just need to know the signal the sensor puts out, and find a gauge that will work with it.
