Rpm drop when not moving
Hi everyone this is my first post and I’m a 16 year old kid with a1995 1500 with the 5.9 v8 and just recently when the truck is running if I’m not giving it gas the rpm’s will drop below 1000 and bog down until the oil pressure drops and it dies but at first if you put it into park or neutral it wouldn’t do that I have 2 o2 sensor codes one says voltage grounded and the other says something like stuck at center. When hooked up to a scanner my rpm’s drop 200 when in gear and my injectors go from 3.7 to 2.4 park plugs probably need replaced but I would like to know if anybody has any ideas
