Transfer Case Vibration at 70 mph in drive or neutral
The fluid that's in there now is ugly. Needs to go.
I changed the fluid. No change in the performance. I think I’ll have the shop take care of the transfer case. If it goes beyond the snap ring I’m in beyond what I’m comfortable with.
I had my transmission guy ride with me and he said replace the rear u joint. Though they moved well in the yokes upon my inspection they had grooves on the spindles (see example image). I replaced both. I would not have thought it was the u joints!
Wonderful. Glad you got it solved. U-joints are a typical culprit with age & use.
