spacer? Right wheel only? 96 Ram 2500 4x4 3/4 ton
Old Jan 9, 2024 | 01:21 PM
AtomicDog's Avatar
AtomicDog
Thanks for updating us that the truck is running larger wheels. The spacer was likely installed to stop the rubbing on that one side due to the wheel/tire choice. For example, I run 285/75/16 tires on 16x8 factory aluminum wheels with no rubbing whatsoever..
Old Jan 9, 2024 | 03:45 PM
Being between the hub, and rotor, wouldn't effect wheel placement. Wonder if the rotor was rubbing on the caliper bracket, or some such.
Old Jan 9, 2024 | 04:45 PM
Wolfen1086's Avatar
Wolfen1086
If that was the case they would have put them on bo0th sides and bigger spacers, I bought the truck off of my boss at work, when he had it it had the stock wheels on it, the asst shop supervisor had the wheels off a dodge he had up in his shop ion Va, that was getting new wheels so they put them on my truck and didnt put a spacer in anywhere
nope, no signs of any rubbing, except the square bearings colored blue that fell out of the left hub LOL
Old Jan 9, 2024 | 10:06 PM
AtomicDog's Avatar
AtomicDog
Sorry, I misread that the spacer was between the hub and rotor. Still, weird..
Old Jan 10, 2024 | 10:09 AM
Gotta agree with that sentiment.
Old Jan 10, 2024 | 11:58 AM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
As I did also. I researched the parts manual for a 96 and a 01 4x4 2500 and 1500. There are no spacers from the factory.
Old Jan 10, 2024 | 05:19 PM
Wolfen1086's Avatar
Wolfen1086
Yea tell me about it, along with why is there only one on one side
I looked in my manuals too theres no spacers installed on either wheel from the factory which means SOMBODY down the line installed 1/4" spacers and somebody else changed tye left front hub and not the right and saw a spacer that didnt belong thaere and tossed it
I called Tidewater Dodge today at lunch and asked to speal=k with a tech, when he go on the phone I asked about teh spacer on eth right side, HE said as long as my wheels dont have teh oppsoite offset ( inward instead of outward) spacers werent supposed to be there and that I sould just toss it
Old Jan 10, 2024 | 05:27 PM
That spacer wouldn't change the wheel position though. It simply moves the rotor further away from the wheel......
Old Feb 11, 2024 | 04:48 PM
Wolfen1086's Avatar
Wolfen1086
It aligned perfectly I asked Joe if any wheel was out farther he said no, so either somebody forgot one a long time ago, or tried one and not the other
