Swapping trans 1998 into 2001
Old Aug 23, 2024 | 07:34 PM
Originally Posted by BIGGDADDYWILLIAM
So did you use the 2000 transducer & governor or the 1998? I just swapped a 2000 into a 98 and I’m getting the same issue where it shifts fine and runs good but after a block or two it throws the temp light and od/off
Electronics mismatch. You need the governor stuff from the original trans.
